KVM for 1440p 144hz monitor+periphal sharing for M2 MBP + Windows desktop
Hey,
I’m browsing around for a KVM for my WFH setup.
I stumbled upon on old thread [L1 KVM recommendation for PC+Macbook setup (high refresh rate monitors)], that is close to my setup, but not quite. (Seems I cannot put links).
In my case, I only have 1 monitor (Dell AW3418DW), although I suspect the answer might be the same despite age and that difference (so apologies if that is the case, but the landscape is still a bit confusing to me).
I have an MBP M2, that I would like to connect with a single cable to the KVM for peripherals, monitor and power delivery.
Then I would like to connect my desktop to the KVM well (RTX 3090, Ryzen 3950x), for easy switching between work/gaming.
Are the options still the same, or is there a better way now, given the single monitor?
