aj0413
March 20, 2022, 8:15pm
1
Mostly just checking to ask if the KVM on the store should be good with the following setup:
1.4 Display Port KVM Switch - Dual Monitor - Four Computer — Level 1 Techs
Have three windows laptops and one macbook and need to hook them up to two monitors and peripherals.
I recall that there use to be issues with macbooks and the whole USBc deal, so just wanted to confirm if there would be any issues with this.
Alternatively, it is the new Macbook Pro so should be able to do a HDMI to DP adapter.
Also I assume there won’t be a USBc w/ power delivery equivalent to the above KVM anytime soon?
@wendell
Moshi usbc to dp cables or usb powered HDMI to dp is highly recommended.
Other than that sounds pretty standard. 10 series house need a firmware update from nvidia.
Vegan and Radeon vii can have weak output fixed in the driver or with a repeater. This only affects a small % of cards.
aj0413
March 20, 2022, 9:44pm
3
Good to know.
I think all the windows laptops use just intel integrated iGPU since they’re all business Thinkpads, but I’ll need to double check with the wife since this is for her.
Given that she’s constantly getting new client laptops probably a good idea to err on caution.
system
Closed
December 19, 2022, 3:45pm
4
