upgraded to kubutnu 17.10 last night and this morning i can report 2 problems
the first is pulse audio crash. the audio section shows no output or input devices available.
running pulseaudio from term shows
E: [pulseaudio] module.c: Module “module-switch-on-connect” should be loaded once at most. Refusing to load.
E: [pulseaudio] main.c: Module load failed.
E: [pulseaudio] main.c: Fail to load daemon.
fix found already, just comment out some lines from the pulseaudio default.pa file. see below:
https://www.kubuntuforums.net/showthread.php/72510-No-audio-volume
second issue
keyboard repeat is not working. if i press f and hold i get no other characters, checked the keyboard repeat settings and it shows as on but no dice. this is especially annoying writing as you can’t hold arrow keys to get around.
third issue probably related to second issue.
in vi pressing insert to start editing gives me replace instead but doesn’t show me what mode I am in.
teething pains i guess.
