Kraken X60
My kraken X60 is currently mounted in my NZXT Phantom (original) just by two screws, and duct tape... i would like to drill 6 more holes through my case to allow a proper secure radiator mounting. But, after futile attempts of trying to figure out what size of screws that they are... i found a number of 6/32X 1.25inch... went to the local hardware store... and found the drill bit to be quite big... Does anybody know what size of drill bit i would need to use for this case/water cooler mod?
Easy way - take screw out, go to hardware store - ask for help. "Need some of these and an applicable high speed drill bit"
6-32 x 1.25 is spot on btw.
