Kraken x60?
Does the Kraken X60 fit in the Corsair 650D with no modding?
Yes
http://icrontic.com/uploads/features/2012/11/Kraken-Compatibility-PR_Page_2.png
if you read the table you would see that it says 140 or 280* and the asterisk indicates that the 280 will only fit with hole modifications according to the sit of nzxt. therefore the x60 WILL NOT FIT in a obsidian 650d without hole modifications.
Whelp, I'm an idiot. No more posts from work. No time to proofread.
Would it be hard to mod new holes for the mounting or should i just consider a different case?
You would just need to line the holes of the x60 up, mark their spots, and drill an appropriately sized hole (whatever matches the screws used for the x60 fans), and screw the x60 in.
