I wanted to know if the kraken x41 will fit in my n200 there is a 140mm fan mount up there but I don't know whether it can fit a rad
plz help
plz help
According to the NZXT website, no. That does not mean you couldn't mod your case and have it fit. The problem is the placement of the 140mm fan at the top. The cooler looks like it would hit your RAM at the very least. You would be better off with a H100 or H80. The case is compatible with 120 and 240 rads.
I am aving trouble finding a source to buy the X41 Kraken in Germany, Has anyone in Europe bought this yet?
The X40 is available via amazon etc
