SDEcho
July 12, 2014, 5:17pm
1
Hi Tek Syndicate forum,
I have a question regarding the Kraken G10. Right now i have a GTX 670 DC mini and I am wondering if the Kraken G10 will fit on it.
http://www.nzxt.com/product/detail/138-kraken-g10-gpu-bracket.html ( Kraken G10 link)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121768 ( GTX 670 link)
Thanks,
Scott
Most likely not due to the pcb not being reference.
It should work but the fan is just gonna be hangind out doing nothing. Space maybe a issue in a small case. But just in case it doeasnt heres the spec sheet
You might see if you can google up a comparision of a reference pcb verses the one on the mini and see actually what the difference is.
