Hello Logan,
firstly, I would like to tell you that I love your YouTube channel and I watch every single video you upload so thanks and keep up the good work :)
Im looking to make a 3 monitor system which I might be run couple of games ,but mainly for productivity.
I watched your older videos about the 27" 2560x1440 Korean monitors, namely Qnix, Shimian , X-star.
Its obvious that you prefered the Shimian ,but now there are newer ones from Qnix and also there are the Crossover ones which have very nice pivot stands. I also want to know about overclocking capability for them. I have heard people going over 120Hz on them.
Shimans seem like they're more expensive than Qnix and Crossover ones
Or is it better to save more money and buy reputable brands like Asus or Dell.
Here are the Links for the best prices I found on E-Bay
Qnix 4ms Multi input ports $319.90
http://goo.gl/f0fRMJ
Crossover 6ms Pivot Stand $339.99
http://goo.gl/xcXCBn
Achieva Shimian 6.5ms $410.40
http://goo.gl/1taOeV
PC Spec:
- i5 4670k Stock
- Sapphire Tri-X R9 290
- Ram 8GB 1866 G-Skill
PS: sorry if I misspelled something or made a grammar mistakes. English isn't my 1st langauge
