I’m seeing some more variations of this monitor… I am wondering how it compares to microboard, Wasabi etc… Still haven’t spotted any DP1.4 from Korea but I will post here when I do.
34" WQHD (3440x1440) FreeSync Cinema Wide CURVED Monitor
3ms&100Hz (144Hz for WFHD: 2560x1080) only for DP
Crosshair (Red, Yellow), Flicker Free, Low Blue Light, 3ms
PIP&PBP, Adaptive Sync (AMD), Black Level, Overdrive, Anti-Glare
DP 1.2, HDMI, DVI
For $709? Hmm, I don’t think it’s worth it when you can buy the Samsung CF791 at a similar price now.
Here’s one that might be worth looking into. I’m strongly considering this monitor. @wendell or anyone. Is this the best monitor (highest resolution/refresh/panel) at the price point? I’m looking for speed and color accuracy.
Pixio PX347c Prime 34 inch Curved Ultra Wide QHD (3440 x 1440) AMD FreeSync 100hz Widescreen Display Professional Gaming Monitor Samsung PVA https://www.amazon.com/dp/B074BCSCKZ/ref=cm_sw_r_cp_apa_Fd9JzbT4N33QT
freesync range sucks dick on thaf
With my luck I’d buy some 3440x1440 and then they would finally release the long awaited 3840x2160 144hz monitors
That monitor has pretty bad motion blur.
if that pixio had a better freesync range i would pick it up instantly
man… for $500 that 34" PX347c is looking pretty good.
