Koga V2: Vermillion
I recently, within the last year, went a bit mental and bought a pentium 4 gaming PC for 200 dollars on ebay. Koga is a Dell Dimension XPS Gen 4 with a 3.2 ghz 800fsb 2mb cache p4 in it. Idk bout yall but I legit ran that as my main machine from 2009 to about 2014 or 2015 when I finally got a machine from a newer junk yard.
I know a lot about single core P4’s.
However there is a fun qwerk about this macujnes case. It seems to me if I take any dell btx board and put it on the mobo tray, I should be able to run most any dell board in here. Now, I don’t have a dimension 670 to throw in here, let alone the psu for it, but I do happen to have a slightly newer dell board that is btx and has a pentium D in it.
Well the other day, quick side track, I saw a video of someone using the same gpu as in koga to play Rust, Fortnite, and other games at 1080p. Grabted at lowest settings and whatnot, but modern titles at modest performance (30-55 fps with an OC).
So I got to thinking. I am willing to get up to a dell dimension 670 board to make a netburst based pc play modern stuff. I am going to make a little thread here to play with this old hated architecture that I used to love. I want to see what bashit garbage I can make happen, and I want yall to join me for the ride.
I will be recording and taking pictured and probably making a video along side this. But I miss my ole project posts so I decided to do one with it.
Other video still in progress btw but I need to do something else first before continuing that so I am putting it on hold.
Yeet thread incoming
my first step will be in storage.
Before even looking at the other boards that I have laying around, I want to look at what drives I have around here and what drives I am using in the machine. I don’t want the machine to have any chance to choke on data. Though IMO I never needed more than a SATA6G drive before on a P4.
I have an SSD that I am booting from, however it is only sroing OS files. usr/bin is even going on another drive, I just want OS files and updates on the ssd. Fast boot, idc otherwise for right now. Esp if I set up my nas.
I am a little concerned about the cpu cooler actually being at the front of the case, and what I would make a shroud out of, if the board would fit. and if I can’t do anything about it, alcan I hack a 925XE board to take a pentium D that is technically the pentium 4 dual core they were gunna repease?
hmmmm
questions!
More on this tomorrow tho I will just edit thisbpost its about bedtime and I have soldering to finish yet
Sounds cool. My first modern PC was a P4 dell as well. Never went mad with it as I didn’t know about all that back then. Would love to see what they sort of stuff cannget up to.
Wasn’t koga the gym leader for fuchsia city, not vermillion
Thats the biggest irony ever I just chose names I like
gym battle with a computer lulw
So a little update here. I am still working on other things but while everything else is tetrising I had to put Koga in place. Well I just changed out some of the parts inside and I’ll get to the board later but I figured I’d show yall.
So first thing was looking at what needed to be moved atound. There was a drive in there I forgot was there so I took it out, redid all the sata cables, changed some cards around and swapped gpus.
Looks nice
I want to use the 8800gts that was in here with my pentium M laptop with my gpu dock. I gave the machine a 6770 1gb with gd5 so that’ll be as much card as that box can handle.
Finished cages!
Either tomorrow or the day after I will be tackling the board going into the machine. I currently am not sure if the other board will fit as I am afraid the drive cages and CPU cooler will interfere with each other. If not, I think I can get it to work with an airfunnel attached to the cooler from the plastic one dell made. Theres 2 high static preassure fans in there, no need to swap.
More info soon
