If anyone can help me map the non-working buttons on this remote, I’d greatly appreciate it. I’m going to go ahead and submit this post and update as I try things. In Windows, I was able to fully configure my remote by adding all three devices that the IR receiver shows within EventGhost. It doesn’t appear that this receiver is fully supported by LIRC, but it’s quite possible I’ve misconfigured something. This wiki page describes the different pathways of communication from remote to Kodi, but I’m still not clear on how to proceed.
dmesg | grep Formosa
[ 4.215123] usb 1-9: Manufacturer: Formosa21
[ 5.249685] input: Formosa21 IR603 HID MCE Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:147A:E031.0002/input/input4
[ 5.306686] input: Formosa21 IR603 HID MCE Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:147A:E031.0002/input/input6
[ 5.306763] input: Formosa21 IR603 HID MCE System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:147A:E031.0002/input/input7
[ 5.306988] hid-generic 0003:147A:E031.0002: input,hiddev0,hidraw1: USB HID v1.11 Keyboard [Formosa21 IR603 HID MCE] on usb-0000:00:14.0-9/input0
[84857.934142] usb 1-13.4: Manufacturer: Formosa21
[84857.941139] input: Formosa21 IR603 HID MCE Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.0/0003:147A:E031.0008/input/input28
[84857.997328] input: Formosa21 IR603 HID MCE Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.0/0003:147A:E031.0008/input/input30
[84857.997398] input: Formosa21 IR603 HID MCE System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.4/1-13.4:1.0/0003:147A:E031.0008/input/input31
[84857.997574] hid-generic 0003:147A:E031.0008: input,hiddev0,hidraw1: USB HID v1.11 Keyboard [Formosa21 IR603 HID MCE] on usb-0000:00:14.0-13.4/input0
lsusb -v -s 001:012
Bus 001 Device 012: ID 147a:e031 Formosa Industrial Computing, Inc.
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x147a Formosa Industrial Computing, Inc.
idProduct 0xe031
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 119
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
cat /proc/bus/input/devices | grep MCE
N: Name="Formosa21 IR603 HID MCE Keyboard"
N: Name="Formosa21 IR603 HID MCE Consumer Control"
N: Name="Formosa21 IR603 HID MCE System Control"
mode2 --driver devinput --list-devices
mode2: unrecognized option '--list-devices'
Usage: mode2 [options]
ls -l /dev/input/by-id | grep Formosa
lrwxrwxrwx 1 root root 9 Feb 22 20:28 usb-Formosa21_IR603_HID_MCE-event-if00 -> ../event5
lrwxrwxrwx 1 root root 9 Feb 22 20:28 usb-Formosa21_IR603_HID_MCE-event-kbd -> ../event4
mode2 --driver default --device /dev/input/by-id/usb-Formosa21_IR603_HID_MCE-event-if00
mode2: could not get hardware features
mode2: this device driver does not support the LIRC ioctl interface
mode2: did you mean to use the devinput driver instead of the default driver?
mode2 --driver devinput --device /dev/input/by-id/usb-Formosa21_IR603_HID_MCE-event-if00
mode2: initializing '/dev/input/by-id/usb-Formosa21_IR603_HID_MCE-event-if00'
This program does not work for this hardware yet
mode2 --driver devinput --device /dev/input/by-id/usb-Formosa21_IR603_HID_MCE-event-kbd
mode2: initializing '/dev/input/by-id/usb-Formosa21_IR603_HID_MCE-event-kbd'
