Kk planing ahead wanting to build my gf a gaming rig for xmas,?
wanting the most for the least amt ... and in red what would you do
O and she loves the ps4 ctlr so i will need to have Bluetooth
Budget? Or what are you aiming to run? Otherwise you should use 4 x GTX 1080, 1500W PSU and 128GB of RAM.
Does size matter? Seriously, the size of the system...
Yeah we need a bit more info the really suggest anything imo.
for budget i would like to be around 600-700
looking for a decent gaming rig, mid tower, bluetooth and prob a ssd for the main hard drive then a 1tb for the storage
Dose the OS need to be included in the budget?
Any used parts or only new?
If you check the buy used sell trade section of tek syndicate I'm trying to sell off my CPU motherboard RAM and graphics card
I5-2500k up to 5.1ghz
Asus p8z68-v Pro gen 3
32gb intel extreme masters sp edition 1866mhz ram
Evga Gtx 970
I'm willing to sell it in pieces and I'm also willing to sell it as a whole unit
Cpu mobo and ram for like $500
I do have a spare a mid-tower case that I could put that in
as an entire unit this is what it consists of
http://pcpartpicker.com/list/Wksfr7
If it's all new parts, and if the RX 480 has favorable reviews, then this would be a solid starting point.
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($197.99 @ SuperBiiz)
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard ($67.98 @ Newegg)
Memory: PNY Anarchy 8GB (2 x 4GB) DDR4-2400 Memory ($27.99 @ Amazon)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive ($35.33 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Case: Cooler Master N200 MicroATX Mid Tower Case ($42.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($39.99 @ NCIX US)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($29.99 @ SuperBiiz)
Total: $489.15
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-06-22 04:43 EDT-0400
This is what I came up with for 600$ Pc Part Picker
For bluetooth you can get a USB dongle for 20$ from any store and, at the same price, a copy of W10 from online key seller like G2A.
nope I already have windows 7 64bit lines up for it
prefer new parts
Just be aware that the skylake set of cpu's doesn’t support windows 7 it doesn’t mean it wont work but Microsoft doesn’t support it.
kk tkx for the heads up
kewl thanks, the only thing is i need to find either a red or yellow case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139043&cm_re=corsair_case-_-11-139-043-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146217&cm_re=Nzxt-_-11-146-217-_-Product
http://www.newegg.com/Product/Product.aspx?item=N82E16811146086
you sir are awesome, personally idc about my cases they are black black and black but she dose lol women :)
