KIOXIA CD8-R on a budget connecting to M.2 slot
Look I’m looking at getting some of these drives to play around with, they look like a SAS interface but that definitely not the whole truth.
Are they NVMe drives with SAS interface that work with normal SAS Cards or it something totally different?
Could i use say one of them M.2 SFF-8643 to 4X SAS SFF-8482 to run the drives?
PCIe Gen4 x4
Most you can do is 1 drive cabled to 1x M.2 slot
Realistically, you need a MoBo and CPU that supports bifurcation and a multi drive adapter card.
Else, you could run an HBA but one that can handle that speed and iops will destroy any dreams of being on a budget
I believe the CD8-R uses a U.2 Connector to provide the PCIe interface. U.2 is just a connection(like M.2), and NVMe != SAS/SATA in terms of compatibility.
They use NVMe over U.2, which can be adapted to M.2+Power (often SATA) or PCIe.
Be aware these drives need airflow, else they complain about being too hot.
Cheers for the info.
I’ve ordered up a M.2 to U2 interface SFF-8639 to play with, single drive.
I’ll do a bit of testing on it,
tbh i’ve got about 20 x 3TB SAS drive was looking at a way to used them, plus a system drive on the CD8. Going to build a backup server for PCs plus my Jellfin.
I’ll probably use a PCIe Card(s) With 10 drives = CD8 once i’m happy with hardware setup.
Just wasn’t sure about my thinking.
My PC has 4x 12TB spinning rust as the dump for less used bulk and two fast SSDs for projects I am currently working on.
For normal 1080p30 media at home, I don’t think you need a CD8-based storage server :slight_smile:
