Kingston HyperX Cloud: PS4 Volume control
Hey,
I was wondering if there is a way to lower/raise the chat volume on the headset while I in mid game? I looked on the internet and downloaded the instruction and does not give a good description on how to use the control box.
Thank you for the help.
The control box likely ties into a windows/linux system. Unfortunately you get what you get with a console, so you are stuck with what ever the system says the volume is.
Ya, i wanted a headset that would work on both my PC and PS4 so I do not have one mic. But thank you for the reply :)
By the way, it is not a software it is a physical volume controller I am talking about.
