Hi, I would like some help in choosing a good GPU for my build and I don't really know what to look for. But I'll list the parts that I have and hopefully I can get some help. :)
Motherboard: Asus P8Z68-V LX
CPU: Intel Core i5 2500k
GPU: Don't really know yet, but considering getting an Asus Radeon HD 7870 GHz Edition 2GB or an EVGA GTX 560 Ti 2GB
RAM: Patriot G2 Series 8GB DDR3 1600 MHz
Storage: Western Digital Caviar Blue 1TB and a Crucial m4 128GB 6Gb/s SSD
PSU: LSP 650 Watt Ultra Professional
Case: Cooler Master HAF Mid-tower
My main issue is figuring out what graphics card I should and will be able to get. My limit for a graphics card is anything over $300 before shipping. Any help is and will be appreciated. Thanks. :)
Overall budget doesn't really matter. The only budget I have setup for myself is for a video card since they can cost quite a bit and because some of the older (more recent ones) will probably work well.
Why are you buying a Z68 motherboard and a hyperthreaded CPU if you don't plan on overclocking? If that is the case get a different motherboard and just a normal i5-2500, don't bother with the K edition. But I really would recoment overclocking and if you end up doing it, grab a Cooler Master Hypere 212, amazing cooler and its $30. I've seen i5-2500k's get up to 5.3ghz with that setup.
