The Pentium is decent in games especially with an overclock but as more games become optimized for more cores the Pentium with only 2 cores, not much cache, no Hyperthreading and lack of certain instruction sets makes it a bit weak IMO. It is a decent placeholder until you get a better CPU like a 4690k.
The cooler you chose is a good option.
The motherboard is quite expensive. Plus I am a bit meh about Gigabyte.
RAM is fine.
Storage. Okay yeah no you have quite the wrong idea here. This will be a gaming and multimedia rig. You are going to want space. After formating, installing Windows and some programs you will have about 60GBs left on that drive. Hardly enough for music, photos, videos or more importantly games. (Hell Titanfall is 50GB!) You are going to want to get a HDD. The WD Caviar Blue 1TB is very good and only $54.
Plus the SSDNow drives kinda blow. Kingston has been using low grade, slow and unreliable flash memory on those drives and I'd stay away.
The Crucial MX100, 500 and my personal favorite the Samsung 840 Evo drives are much better options.
The GPU is a little weak and kinda pricey. Personally the only reason I'd get a nVidia GPU is if you're psycho about power consumption. AMD really beats them at every price point. The R7 265 and R9 270 can be had for the same price as that 750 Ti and will be a bit faster in the case of the 265 and stomp it in the case of the 270.
The CORE 3500 is quite expensive too. The NZXT Source 210 Elite is fine for a basic rig. The FD Define R4 is a much nicer case than the CORE 3500 and is the same price.
430W isn't enough. Yeah it is fine for the GPU you have but you'll need a new PSU if you ever wanna upgrade. 550W is usually about right.
AMD criticisms:
The 4130 is crap. Plain and simple. The 6300 is $10 more and will kill it.
THat motherboard is kinda crap too. There are no good mATX AM3+ motherboards.
Curious as to why the RAM is different?
My recommendations
Intel: http://pcpartpicker.com/p/t8dM4D
AMD:
http://pcpartpicker.com/p/Z99nyc
I'd personally go with the AMD. The 6300 is just as fast if not faster in games, can OC really well, and will be better balanced for editing and other multitasking. Should last you quite a bit even now.
