Killing my console and need help
I am coming from the Xbox 360 and am trying to build my own gaming pc for under $900. I need help finding a graphics card that will run a lot of games at Very High to Ultra settings. Currently I was looking at the EVGA NVIDIA Geforce 760 2GB of GDDR5 ($300). However, I am new to PC gaming and don't know a lot about graphics cards. I am looking to spend around $260 for a graphics card that has high performance. Does this card have enough built in ram to last for 2 years, or will games surpass it almost immediately. I would like to buy my card from BestBuy because I work there and get a discount on a lot of products. The card above would cost me $262. Is there a better card for the same price, or should I increase my budget a little bit and get a way better card? Should I wait a few months for the NVIDIA 800 series to come out? The games that I really want to play the most are BF3, BF4, Call of Duty (I know I am a recovering console fanboy), and maybe try some exclusive PC titles when I see ones that I like. Your help would be very much appreciated. Thank you in advance for your help.
P.S
I have also seen this card, which we don't carry at our store yet. Would this be a lot better for $20 more?
The 760 is a good card, but it won't last very long in terms of performance compared to higher end cards or the new R9 cards from AMD. You mentioned the possibility of increasing your video card budget some, and I would definitely recommend an R9-280x. These are going for about $300 now and will outperform the 760 by a pretty wide margin. They're more in line with the 770, which is a $400 card. Personally I'm waiting for the R9-290 to come out. This card is assumed to be as powerful or more than a 780 and be around $450.
Thank you I will research those AMD cards.
r9 280 wouldn't be a bad card. The 760 would be good, too. Just make sure you get a motherboard with an expansion slot and SLI capable so you can add another 760 when you have the money!
When I built my first system, i did an insane amount of research, and that's what I'd suggest. :D good luck!
This is a good strategy also. I'll admit I'm an nVidia fanboy through and through, but even I can't ignore what AMD is doing now.
