I do really think that Logan should do an episode where he recommends a build from ebay's buy-it-now prices for something to kill your console with. I just recently did such a build, because I am poor and it was the only way for me to get something sufficiently powerful to play with.
My Build:
$65 MSI G41M-P25 Socket 775 motherboard
$45 Intel Core 2 Quad Q6600 at approx. 3 GHz
$20 Thermalright True 140mm cooler with 2x Coolermaster static pressure fans
$125 MSI ATI Radeon HD 6950 (unlocked to 6970)
$69 Thermaltake 450W PSU
$45 Western Digital Caviar Blue 320 GB HDD (existing)
$35 Kingston Hyper X Blue RAM 8 GB (4GBx2)
$?? HP Pavilion 752n Case (existing) modified to accept a 120mm Corsair high air flow fan.
fans cost about $40, but those were a gift, so you needn't spend that much to buy some serviceable fans.
If the Radeon HD 6950 is a 2 GB card with a reference PCB (usually conjoined with a reference blower-cooler) then the unlocking tool will work about 60-70% of the time. Otherwise, expect to pay closer to $170 for a true Radeon HD 6970.
I've not had a chance to test this rig out on many of the typically crushing computer titles, but I will be doing so in the near future. Currently I've been playing a HEAVILY modified version of Dark souls with the full HD pack and SweetFX at full 1080p. It is beautiful and rarely now dips below 30 fps (which is the rendering cap unless adjusted in DSFix, Doing so may cause instability.) Unfortunately, I've found that my card is not stable at a forced overclock, although the BIOS which is loaded has alternate boost clocks at 950 MHz and memory clocks at 1450 MHz, so all is well.
If all you must have is something that will replace your console, you can't go wrong with an inexpensive build like this. Just make sure that you buy from reputable sellers; and if the price looks too good to be true, it is.
Note the preposterous size of that graphics card compared to the remainder of the build. And yes, you eagle-eyed forum scrollers, that is an IDE/PATA ribbon cable. I carried this HDD over from the system that was previously in this case. Because I can get data transfer speeds of about 30 Mb/s I'm still a bit loath to replace it. There is a tiny bit of PCB visible on the Radeon HD 6950 just below the Crossfire connector. This is the BIOS switch and is a vital part of the unlocking process (the cards frequently refuse to overwrite the BIOS that they are currently running on, so you boot into one BIOS and then you switch the BIOS while the machine is running and overwrite the other one.)
There is only maybe a 1mm gap between the Thermalright True 120mm cooler and the PSU. The bit of black that you see between them is a fan cable that I have been forced to sandwich between the two. On the plus side, it does prevent contact.
Then the graphics card in question:
I do find the sticker to be a bit garish, but as you can see in the other picture, it isn't as though I can see it clearly. I will be popping off the cooler and either painting the red accents to blue, or using a vinyl sticker to cover them. The fan can be red, it honestly doesn't matter, since I can't see it. Also, to anyone looking at just this same card from MSI: this thing is seriously heavy. It has a 1-2 mm thick backplate on it. Although this provides astonishing rigidity, it does add quite a bit of heft to the card. It also adds an additional few steps to the disassembly process that I have in the works.
So; the disassembly of that GPU is really a pain, and because nobody saw this post at all, I didn't take pictures of any of it. So sad for you. This GPU cooler was stuck on with a ton of screws, and the seller had attempted to boost the performance of the thermal solution with some Arctic Silver 5 that he slapped on there. It wasn't a good attempt. Take this as a warning, test your products as soon as they arrive, and be prepared to replace the thermal paste, at a minimum. I actually replaced it with Antec Formula 7. Why did I choose this over, say, Arctic Silver 5? Because the die is exposed on the GPU, and certain components like RAM, VRMs and anything nearby will be exposed to the thermal paste (you can actually buy replacement strips of thermal pads, but I find a high-gap compliant thermal paste works a charm.) The reason for going with Formula 7 is because it rates quite nicely even compared with Arctic Silver, and it is not electrically conductive. I've also tried varying methods of application for the thermal paste on this one, and I've found that the best method is a modified x-method. You put the x on the die, a thin line of paste about 2mm from one corner to the same distance on the other, go from the center to the other corners, then make a dot equidistant between the two points on each side. This pattern fills the die surface completely and very, very evenly. The primary reason for the modification on this: there is no heat spreader and the die is quite large, so full coverage is important.
Okay, so I downloaded and installed a few new games. I'm going to be giving my objective opinion about the playability of them, because to be honest, if I can't notice the difference between 30 and 33 fps, it isn't going to make a real-world difference. Also because I couldn't be bothered to download a frame counter, or do multiple play throughs of a section with different graphics settings.
Crysis 3: I'm playing this with most of the settings at high, with low filters. On my 32" 1080p television, this game is absolutely beautiful. The rain of the first area is definitely a GPU killer, and it drops performance like a rock. However; set at high, instead of ultra, with motion blur off and filters on low, the GPU churns out a reliable frame rate to give you adequately smooth playback. Inside, the frame rate jumps back up to a more reasonable rate, at least above thirty. I suspect that once you get out of the rain entirely, this game would return about 30 fps on this system with the settings turned up to ultra.
Borderlands 2: turn PhysX to low if you don't want to explode your CPU, turn everything but the filters up to max and enjoy the show. Frame rates are always above thirty, and gameplay is buttery-smooth.
DMC: I haven't done much of a playthough of this game on this system, but the framerates are nice, and on my display which does a lot of adaptive sharpening on its own, this game looks even better than usual.
Dark Souls: This game, stock, is really still very pretty. On top of that, the system requirements aren't that high. It plays at around 60 fps continually. Add in mods like the high-res everything and that drops closer to 30 fps. This game does not tolerate software overclocks of the GPU, so don't even bother. But damn is it pretty.
Skyrim: Still testing.
If anyone has any games that I can either try for free, or that aren't very expensive, please let me know.
