Kill My Console #2
Im looking to build a computer that will out perform the ps4
but i want to keep it under 700$ could you guys help me?
Im completely new to PC gaming so i know little to nothing
i want to be able to play all the latest games like battlefield 4, watch dogs, assassins creed 4, call of duty ghosts
if it goes a little over 700$ thats ok but not too much, im on a tight budget.
Hello,animeaddict7,may I ask,do you need peripherals such as keyboard,mouse,monitor,etc?
If not,I'd probably recommend this build:http://pcpartpicker.com/p/1KMaK
thanks so much, so with this i will be able to play those games on the highest settings?
Here’s a better build http://pcpartpicker.com/p/1KMtz
And Wait for the new amd gpus they will be much better value for money with better performance
heres 2 video's i made on youtube, they are near the $700 mark, you can use both to compare specs for both builds:
$600 PC: http://youtu.be/LdhyfllFx7c
$750 PC: http://youtu.be/YY7f89yuvYk
Your PC build depends a lot on what functions you want, I personally prefer Nvidia graphics cards, as I like the design, software and of course the overall power of the cards itself. Of course you don't need to dig way into this as you're obviously new to PC gaming. Some of the builds other people posted above, seems really reasonable, and the price range is also great; if you ask me. The only thing I'd change in oneillzki's build, would be the case and the power supply, as it's easier to upgrade in the future if you got a bigger case, as it fits SLI/Crossfire better, and I'm not sure if a 500watt power supply would give enough watt's to power 2 7970's. You could also, as animeaddict7 said, wait for AMD's new proccesors, and their new gaming card series.
when are the amd proccesor and gaming card coming out?
I did not manage to find the release date of their new series og CPU's, although I found the pricing of it; http://www.tomshardware.com/news/AMD-FX-FX-9590-FX-9370,23119.html So far, the pricing has been put to some where between 500$-950$, which is higher than I would have expected in the first place. You might want to stay with some of their cheaper series, or maybe move over to Intel, which I prefer.
The graphics cards part, I'm kinda on deep water, as I'm not into AMD as much as I'm into Nvidia. The only thing I know about their new series of graphics cards, is that there's gonna be 2 different 'ways': the high end gaming graphics cards, and the mid/low end graphics cards, and the prices will wary a lot.
I just checked AMd's official website, and they want me to enter a password and a username to enter their new R9 graphics cards serie page. I guess they're not interrested in the majority to check out their new graphics series yet.
