Keys sticking on Razer Deathstalker
So about 2 weeks ago I spilled a little bit of pop on my arrow keys on my Razer Deathstalker, and now its annoying the crap out of me how they keep sticking.
Does anyone know if there is a specific way to remove the keys so I can clean them? I want to be sure of how to do it before I even try, so I don't damage the keyboard.
Well you have two options.
Either Take apart the keyboard to get to the chiclet style keys, because they dont come off from the front easily.
OR
Unplug it, use a damp cloth and wash that part of the keyboard, then let it dry before plugging it back in.
