KeyPad recommendation
Currently I am trying to decide whether to spend what a good hooker would cost, on a gaming keypad, it seems a gamble as I dont know if I would enjoy the keypad as much, let alone use it. or just stick with saving up for a K70 rgb  when it comes out.
Are all keypads internet dependent to use their programmed Maps that you have programed ?  From what I gather, Razer Snapse 2.0 uses a cloud system to store your Map profile but if this is not wanted, can it be stored on the device or PC?  I find that there is way too much presuming we all live in the cloud.  it's hard enough in a Grob 103
I have large hands and would probably also use it for AutoCAD and photo editing if it were to be as good as a hooker.
I have looked at the Razer Orbweaver , the Nostromo is too small and if the Tartarus is the same size, ditto. Any suggestions on other units & models Any help would be greatly appreciated.
