Keyboards please!
Anyone have a good recommendation on a wireless gaming keyboard? I have the mouse covered. Any help is appreciated.
Wireless and Gaming can't go in the same sentence man
Really though I don't think you have too many options
This one's like $160
Take it from me, who uses a bluetooth keyboard....it just doesn't really work well. Any minor interrupt in the signal (even if it's just a millisecond) can screw with the keeeeey presses, sometimes unecessarily elonnngating words because the computer was still receiving the signal for the laaaaaaaast key pressed.
(okay, so I exaggerated the key interrupts above, but...something like that.)
Rapoo KX mechanical keyboard - uses 5ghz wifi which is nice since b/tooth is shit. Has a non-cherry Kailh switch but they feel ok. I've only tried them in store and they feel quite nice. Backlit as well.
Filco make great boards as listed above. There is also the Varmillo VB87M that pops up on Massdtop often enough, if you cannot wait you can usually find them on AliExpress too.
I've gamed a while on a Logitech K400. It has a touchpad too but otherwise quite small. I would not play competitive CS:Go on it but it get's the job done and is cheap. Once in a blue moon it disconnects or lags on you but I've found that a simple on/off cycle of the keyboard switch does the job.
Plus it comes with the Logitech Unifying Adapter for which there are a lot of other peripherals. Plus they are relatively cheap if you happen to lose one.
Probably the cheapest wireless keyboard that is okay you will get. If you pay more you get better keys.
