Keyboard Advice?
I'm in the "contemplating" stage of my first build. I really want to have a green color scheme, and I actually have an idea of everything I'd like to have...except for a keyboard. With green, I'm pretty much limited to either the BlackWidow Ultimate or the K70 RGB.
The K70 is a bit too spendy. I mean, even though I'm not buying it tomorrow, it's still alot of money. But I like the way the LEDs are positioned under the key switch housing. I've messed around with the BlackWidow a bit at Best Buy, and I like the feel of it, but I've seen alot of mixed reviews about it. But then, it's alot closer to my price range.
So what do you guys think? Any advice would be awesome. And are there any other options that would go with a green scheme?
Oh, and here's what I'm thinking of so far: http://pcpartpicker.com/p/L4D499
If you get a keyboard with cherry white led. You can buy green covers for them https://www.massdrop.com/buy/led-color-changer  There called daydream LEDs you can find them in other places but you have to Google for them.
PS they don't work with low profile key caps
I've used colored tranalusent tape from a craft store but not every key survived
That's not a bad idea. Thanks
