So I am running both an nvidia gtx 660 and an r9-270x. I use them both for different things, but if they're both full load my system gets crazy hot. I had to open the side panel of my case and point a giant window fan in to keep things below 80. How do people keep dual gpu systems cool? What's the best way? Whats the cheapest way?
how many fans does your case have (how many in/out/how many more spaces in your case do you have for more) and what case to u have. also whats the ambient are temp in your room.
i persoanlly have never ran 2 cards, im not sure how you are using both at the same time unless its just for each running main screen, obviously not able to sli/crossfire.
Good case airflow and not retardedly high ambient temps. The lower the relative temperature in the room which the computer is in the lower temperature all of your components will be.
