I got like about 50 bucks to spend, I need an AM2 motherboard and Memory modules if its not a normal DDR board.
It needs fairly decent IGP, Something better than an FX5200
For my arcade machine.... Halp?
ok man, check out this [url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4433878&CatId=2321]Biostar MCP6PB M2+[/url] it has a ok IGP, nothing special, but better then a FX 5200 I would think
Do you live in the US? IF you do, I could send you 512 MB of DDR2, unless you want to buy some on tigerdirect
[b]
EDIT get [url=http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4471587&csid=_22] this stuff[/url] but leave out the case, and CPU, and you would have a good mobo and some ram (3 GB)[/b]
I live in Arizona. :]
I need good video to play games like Street Fighter III: 3rd Strike and other CPS3 based games...
Probably going to end up emulating Guilty Gear and Tekken too.
Emulators suck dick with a Dual Core but they mainly rely on memory, I need some fast modules
So pretty much Good IGP and fast memory = good arcade machine
get a AM2 board with a Radeon HD 3200, it is the [b]BEST[/b][u] IGP out as of now, I think
