Kaveri and 270X
Is the Kaveri 7850K compatible with the r9 270X with a custom Asus cooler?
If so will it accelerate the GPU on the APU or will it just be like having a CPU with a 270X (for gaming.)
If not then what GPU is good for accelerating the GPU on the APU and not be like having a 270x on its own with a CPU.
Also (as a last resort) will I be able to disable the GPU on the APU and put it back to a CPU (like a Athlon 760K etc) and put a 280x with it etc.
Thanks in advance.
From what i know you can only crossfire the 7850k with R7-series graphicscard like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127762
It will be the same as having a CPU and GPU for gaming. The 270x is perfectly fine with the 7850k. Though, I would recommend purchasing a cheaper 750k. The CPU performance between the 750k and the 7850k is only small. No point paying for the 7850k with integrated graphics because you don't intend to use the integrated graphics.
I could be wrong, but I believe the aforementioned APUs will bottleneck and high-end GPU like the 280x. I think the 270 or 270x is probably the top performing GPU that you could place in an FM2 system without creating too much of a bottleneck.
Thank you for your help...
I asked if i could disable the graphics on the 7850K to downgrade it from a APU to a CPU.
Can you or not crossfire it with the 260X and can it go up to a 270X.
Just plug in the GPU and it will perform as intended.
You can crossfire with the 260x but not the 270x.
You can only CF 7850k with R7 240 and 250. If you can, get an 8320 instead of an APU if you're going for a dedicated GPU. It costs less and performs much better.
