So i recently built a small form factor PC ( following the crowd) for gaming and general use, the specs are as follow
Case - Corsair 250D
CPU/GPU - A10-7850k
MOBO - Gigabyte itx A88x wifi Board
CPU Cooler - h80i
RAM - 8gb ( 2x4 ) Kingston beast 2400mhz
PSU - Corsair rm450
OS - Windows 8.1 64bit
Storage - Samsung evo 120gb ssd and a WD Black 1tb
Anyway, As the subject states i was planning on overclocking this new apu but to be completely honest ive never even touched an apu until today and i was hoping someone on the forums could help. Ive tried looking for sites that give guides but i cant find one that would really help me. I have overclocked alot in the past as i have previous full custom water loop builds but i want to make sure i know what i am doing. If anyone has first hand experience or knows a fairly detailed overclock guide ,so i can squeeze this things power for all it has, Id appreciate it if you'd link it to me below ;]
It's really not that different from OCing a regular CPU - raise the multiplier, test/monitor temps, adjust voltage, repeat. The only quirk to APU overclocking is that CPU temperature monitoring utilities won't read the temperature properely, but GPU monitoring utility (such as GPU-z) would, and since the CPU and GPU are on the same die, those temps are accurate for the CPU as well.
If you are using the graphics as well, then it can be tricky because you have to balance out the chip's headroom between CPU and GPU (and by extension RAM); one OC on one could adversely affect the stability of another.
Again, you should be fine as long as you keep voltages moderate, keep an eye on those temperatures, and are very patient as finding an optimally balanced OC on all the APU's components will take a lot of trail and error.
Personally, I'd crank the GPU (again nothing different from traditional methodology) as high as I could, play with memory clocks to see if you can squeeze some more, and then leave the CPU last. And once you have all the numbers dialed in, run a full system benchmark on a loop for at least a few hours
Thanks for the response, ill try it out in the next couple of days
