Kale and Beet Slaw
I heard Logan refer to homemade kale and beet slaw over turkey hotdogs on another show he was a guest on awhile back. Do you care to share the recipe ?
I dunno about Slaw, but at the restaurant i used to work at we made a kale and beet salad with quinoa n things if you would like that?
I will take any kale recipe. I am trying to incorporate it into my diet by making it taste good.
Well i got boatloads of them.
Here's the recipe, bear in mind this is from a restaurant recipe card so it makes a lot of assumptions and measurements can be kinda vague. I'll do my best to flesh it out for you.
Peel 3 large betroot and quarter them lengthways, place in a roasting tray with 4-5 decent sized carrots, cut into 1 inch fingers on a bias (cut at an angle)
Toss with vegetable oil, roast at 200 degrees c and toss freqeuently until very well browned.
Cook a cup of quinoa and toss the vegetables in, add a thinly sliced red onion and approx 200g of finely shredded kale, Add a handful of sliced, toasted almonds.
The dressing is just orange juice, orange zest, honey, wholegrain mustard and olive oil, equal parts of each except the honey, 1/3 of that to the rest of the components.
Season with salt as nessesary.
Stilton cheese works great with it, just crumble it over the top.
Thanks , The Stilton cheese threw me a loop and had to google it. I will give this a shot next week.
Awesome, hope it works out for you mate. If you need more recipes just reach out.
