So like 2 hours ago I picked up the corsair k65 Rgb , and its a great keyboard. But whenever I set an rgb pattern, after 15 minutes it freezes and the software said it is "Malfunctioning" I looked everywhere on the forums and didn't find any answers, only people with the same problem. Any help would be appreciated.
Sense you just got it, I'd send it back. If you can't do that then make sure you have tried all of the bios's on the keyboard (look at the back, by the cord). If that doesn't work then try some of this:
Switched the usb connections around and its working just fine now :D weird though...
Yeah... I'm glad it worked out but it's kinda a know issue. Switching back to the messed up keyboard firmware and then trying to update the firmware (2nd pic) should fix the problem entirely.
Also make sure that the reported polling rate matches the switch on the back.
I had weird problems with my k95 rgb for a while until i figured out i needed to change the switch near the cord from bios mode to one of the poling rates.
bios mode is for legacy connections ;P
