I got a Dell Studio 1558 out of the trash last week, or maybe it was this week? Either way the power button was fucked because the socket exploded. So while it was still attached, I was just shoving a screw driver in the socket to turn it on and off. Just now the socket completely broke off. It was already broken anyways and barely attached, now it isn’t at all. Theres still solder points on the pads though so the pads aren’t destroyed.
I wasn’t planning on selling this thing, nor really using it for much more than a toy, but not being able to turn it on is a pain in the ass. How do I achieve this then? I have wake on lan turned on… Can I hit it with a Magi-packet and have it power on? Do I just throw it out? Wat do.
If I interpreted the datasheet for the maxim chip next to the not-anymore connector correctly, bridging the inner two contacts of the connector should result in power on.
However: Two of those pads are 3.3V and GND, those two should never be bridged.
As I am not a hundred percent certain on PCB layout, you are on your own.
Also: the black stuff on screwdrivers may not be conductive enough
Welp doesn’t matter now. I lifted the plastic up, plugged it in (unplugged, took out battery) and started smelling burning. I’m too tired for this I’ll have to look at this shit tomorrow.
Meh. Its no loss, it was just neat to find something in the trash that was 1080p and had good audio.
I think the power-up controller blew out. I got a board of the same series, previous model, that has the same controller. I’ll try to patch it together when I give a shit. Not like I practice soldering all the time lol.
