[JAVA] System Spec & Java Runtime Debbuger
Hello!
I spent the past hour working on this]
It is a simple console applications that is designed to assist in supporting people who are having issues with games that I develop in the future. It retrieves critical information such as the Java VM, OS and the CPU.
Any thoughts, criticisms or possible improvements?
Download can be found here...
Thankyou
I assume this is for Windows only? Only comment I have is that debugger is probably the wrong name for this kind of program since it is not a debugger. Also I think there are plenty of tools already that can gather this type of information for you.
I am aware that there are other tools, I simply thought it would be cool to have a look at what was possible with Java incase I needed to implement into a program later. As far as Windows only, I don't believe that this is window only as it uses native Java to retrieve the information. Although in practice i'm unsure.
