Java programming help
The java interpreter keeps on spitting out this error whenever I access Scanner.nextDouble()
NumEvOdd.java:10: error: non-static method nextDouble() cannot be referenced from a static context
double num = Scanner.nextDouble();
Please help
you need to call nextDouble() on an instance of scanner not the class itself
You are trying to call the method on the type instead of an instance.
There is no such thing :wink:
Well, nobody uses them anymore anyway.
Just correct my code
DecimalFormat df = new DecimalFormat("#.0");
Scanner input = new Scanner(System.in);
System.out.println("Put in your number");
double numHalf = num/2;
switch (df.format(numHalf))
    case 0:
	System.out.println("Your number is even");
    	break;
    default:
	System.out.println("Your number is odd");
	break;
How do you expect to learn when you let others correct your code?
The problem is really simple: You are creating an instance of the scanner, just to then ignore it. Call nextDouble on the instance, not the type.
You know what, you are right, I am being lazy and not really learning by copping out and have someone else see the obvious, thank you
edit: Jesus christ it was so simple, thanks man
// input is an instance of class Scanner
// double num = Scanner.nextDouble();
// This is wrong, .nextDouble() is a method for a Scanner Object,
// this needs to be our input object we created above
double num = input.nextDouble();
    case 0:
    	break;
    default:
	break;
