So I am doing my final project in Programming class and I am having so MANY problems. I am trying to make a program that gives options to people and then recommends a headphone based on multiple things like price and whether or not you want a mic. I am trying to make the answers be in another class so I can have multiple classes (A requirement of the project) I also need an array but I have no idea what I should use it for.... Any help? Describing it doesn't really click to well with me examples work better (Or you can do it for me, JKJK). Thanks in advanced!
This is my main class
import java.util.Scanner;
public class Choices{
public static void main(String[]args){
int choice;
boolean open = true;
//scanner
Scanner input = new Scanner(System.in);
// Welcome
System.out.println("Welcome to TekMeka!");
//Display the open or close
do{
System.out.println("Enter 1 for Headphones., Enter 2 for Headset: ");
System.out.print("3 to Close the Application: ");
//Obtain choice
choice = input.nextInt();
Scanner input2 = new Scanner(System.in);
//Close or open the app
switch(choice){
case 1:
if(choice == 1){
System.out.println();
int pricerange=0;
System.out.println("Enter a budget:");
System.out.println("1: 1-50$.");
System.out.println("2: 51-100$");
System.out.println("3: 100-200$");
System.out.println("4: 200$+");
System.out.print("Enter choice: ");
pricerange = input2.nextInt();
if(pricerange == 1){
System.out.println(incipio);
}else if(pricerange == 2){
System.out.println("We recommend the Sony MDR7506");
}else if(pricerange == 3){
System.out.println("We recommend the Beyerdynamic DT990 Pro 250OHM");
}else if(pricerange == 4){
System.out.print("We recommend the Sennheiser HD600");
break;
case 2:
if(choice == 2){
int pricerange=0;
System.out.println("We recommend the Creative Fatal1ty");
System.out.println("We recommend the HyperX Cloud");
System.out.println("We recommend the Razer Kraken Chroma");
System.out.print("We recommend the Sennheiser PC363D");
break;
case 3:
System.out.println("Goodbye, See you soon!");
open = false;
break;
}while(open == true);
My second class would replace the recommendations so they get accessed there instead of just being a message in the main class.
* Morechoice class
public class Morechoice{
* Constructor
* pre: none
* post: the recommendation has been returned
public String incip(){
String incipio;
incipio = "Incipio F38";
return(incipio);
* Constructor
* pre:none
public void michead(){
I need help lol ;-;
