Trying to get the IPMI console to work on my Asrock J1900D2Y MB.
Connecting from centos 6 machine
installed java1.6 sdk and 1.7 sdk
…and icedtea-web
seeing errors like…
…and icedtea-web
seeing errors like…
I replay because Java is involved but I do not know if it will work…
I found this:
You can try adding the site/file to the “Exceptions” list on the Security tab in the Java Control Panel.
Run “jcontrol” in Linux, or “Control Panel > Java” for Windows.
after reading your link…
it lead me down a rabbit hole where I just found link below and just commented out line in all the java.security files… finally worked. Thanks
