The original website for getting Jad/JAD has been down for quite some time. I was wondering if anyone knows if there is a reliable place to get it.
Perhaps try the Internet Archive’s copy.
Though I’m slightly stunned by your desire to use JAD - it’s very old, and frankly no good for anything made in the last couple of years. Unless you’re decompiling java 5 archives, you want to be using a better + newer decompiler.
CFR is becoming the best decompiler around in my opinion, though FernFlower is good too.
If you’re after a graphical tool - perhaps try Bytecode Viewer, though I’m not sure if it supports CFR :s
I don’t know how trust worthy that is though.
Since it is an archive of the orginal site, not a user uploaded binary, I would trust it more then most other places.
