Running Fedora 30 on an Asrock X470 Taichi with the onboard wireless adapter. Since kernel 5.1.x(? not sure when exactly, but definitely with 5.1.8 i am currently running) i am seeing poor performance and driver/crash reset with microcode software error.
The adapter basically goes offline and needs a disable/re-enable to reconnect. Super annoying, have had about 6 months of hassle free wifi until recently…
Wondering if any one else running this hardware on fedora is seeing similar?
Relevant lines from dmesg:
detected hardware:
[ 6.901579] iwlwifi 0000:27:00.0: enabling device (0000 -> 0002)
[ 6.903393] iwlwifi 0000:27:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[ 6.984407] iwlwifi 0000:27:00.0: Detected Intel® Dual Band Wireless AC 3168, REV=0x220
When it craps out…
[ 450.696226] iwlwifi 0000:27:00.0: Microcode SW error detected. Restarting 0x2000000.
[ 450.696394] iwlwifi 0000:27:00.0: Start IWL Error Log Dump:
[ 450.696396] iwlwifi 0000:27:00.0: Status: 0x00000100, count: 6
[ 450.696397] iwlwifi 0000:27:00.0: Loaded firmware version: 29.1044073957.0
[ 450.696399] iwlwifi 0000:27:00.0: 0x00000EDC | ADVANCED_SYSASSERT
[ 450.696400] iwlwifi 0000:27:00.0: 0x00000220 | trm_hw_status0
[ 450.696401] iwlwifi 0000:27:00.0: 0x00000000 | trm_hw_status1
[ 450.696402] iwlwifi 0000:27:00.0: 0x00043D54 | branchlink2
[ 450.696403] iwlwifi 0000:27:00.0: 0x0004AFA6 | interruptlink1
[ 450.696404] iwlwifi 0000:27:00.0: 0x00000000 | interruptlink2
[ 450.696405] iwlwifi 0000:27:00.0: 0x0ACA001C | data1
[ 450.696406] iwlwifi 0000:27:00.0: 0x2000005E | data2
[ 450.696407] iwlwifi 0000:27:00.0: 0x00001C84 | data3
[ 450.696408] iwlwifi 0000:27:00.0: 0x2DC0CDC5 | beacon time
[ 450.696409] iwlwifi 0000:27:00.0: 0x923B4245 | tsf low
[ 450.696410] iwlwifi 0000:27:00.0: 0x00000224 | tsf hi
[ 450.696411] iwlwifi 0000:27:00.0: 0x00000000 | time gp1
[ 450.696411] iwlwifi 0000:27:00.0: 0x1A633483 | time gp2
[ 450.696412] iwlwifi 0000:27:00.0: 0x00000001 | uCode revision type
[ 450.696413] iwlwifi 0000:27:00.0: 0x0000001D | uCode version major
[ 450.696414] iwlwifi 0000:27:00.0: 0x3E3B4DE5 | uCode version minor
[ 450.696415] iwlwifi 0000:27:00.0: 0x00000220 | hw version
[ 450.696416] iwlwifi 0000:27:00.0: 0x00C89200 | board version
[ 450.696417] iwlwifi 0000:27:00.0: 0x2000005E | hcmd
[ 450.696418] iwlwifi 0000:27:00.0: 0x24022002 | isr0
[ 450.696418] iwlwifi 0000:27:00.0: 0x00800000 | isr1
[ 450.696419] iwlwifi 0000:27:00.0: 0x00000002 | isr2
[ 450.696420] iwlwifi 0000:27:00.0: 0x00417CC0 | isr3
[ 450.696421] iwlwifi 0000:27:00.0: 0x00000000 | isr4
[ 450.696422] iwlwifi 0000:27:00.0: 0x0A99001C | last cmd Id
[ 450.696423] iwlwifi 0000:27:00.0: 0x00000000 | wait_event
[ 450.696424] iwlwifi 0000:27:00.0: 0x00000094 | l2p_control
[ 450.696424] iwlwifi 0000:27:00.0: 0x00018030 | l2p_duration
[ 450.696425] iwlwifi 0000:27:00.0: 0x0000000F | l2p_mhvalid
[ 450.696426] iwlwifi 0000:27:00.0: 0x00000085 | l2p_addr_match
[ 450.696427] iwlwifi 0000:27:00.0: 0x00000005 | lmpm_pmg_sel
[ 450.696428] iwlwifi 0000:27:00.0: 0x03041751 | timestamp
[ 450.696435] iwlwifi 0000:27:00.0: 0x00000010 | flow_handler
[ 450.696437] ieee80211 phy0: Hardware restart was requested
[ 685.039518] rfkill: input handler disabled
[ 819.223747] wlp39s0: deauthenticating from 40:9b:cd:a6:b9:30 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 842.491706] wlp39s0: authenticate with 40:9b:cd:a6:b9:30
[ 842.495331] wlp39s0: send auth to 40:9b:cd:a6:b9:30 (try 1/3)
[ 842.603849] wlp39s0: send auth to 40:9b:cd:a6:b9:30 (try 2/3)
[ 842.604432] wlp39s0: authenticated
[ 842.604849] wlp39s0: associate with 40:9b:cd:a6:b9:30 (try 1/3)
[ 842.606310] wlp39s0: RX AssocResp from 40:9b:cd:a6:b9:30 (capab=0x11 status=0 aid=1)
[ 842.607496] wlp39s0: associated
[ 842.629480] IPv6: ADDRCONF(NETDEV_CHANGE): wlp39s0: link becomes ready
ethtool output
driver: iwlwifi
version: 5.1.8-300.fc30.x86_64
firmware-version: 29.1044073957.0
expansion-rom-version:
bus-info: 0000:27:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
@wendell do you use Intel wifi on recent kernels perchance? Guessing mostly wired… i know you’re an Asrock user and maybe even have a Taichi board?
kernel:
Linux ryzen2700x 5.1.8-300.fc30.x86_64 #1 SMP Sun Jun 9 17:09:32 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
edit:
not sure if i should submit as a kernel bug, from here:
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging
… I’m not sure if firmware is supposed to be reported to the kernel guys as a bug any more?
