Itx univesity sistem
i want to do my first computer build
ihave a budget of $1000
is going to be for gaming and some use of engeneering programs and solidworks
i want it to be a itx case like the coolermaster elite 130 because i need it to be easy to move around
http://pcpartpicker.com/p/2kRJ1
This would be the best that case is very small and has powerful hardware overclockable and with the ssd I would set up intel smart response with the 1tb hard drive.
http://pcpartpicker.com/p/2kW8A
2400mhz ram because it's the cheapest 2x8GB kit that's in stock :/
I would also suggest the Fractal Design Node 304.  It's capable of tower coolers and AIOs.  Just make sure that if you're getting a modular power supply, that's shorter than 160mm, or the cables are positioned like the Seasonic G-550
