Hey everyone!! New to the forum here but I've been following Tek for quite sometime and i really find ITX systems interesting. I've been doing a lot of Lanning at friends houses and slugging around my tower isnt exactly easy or fun, so I've been looking into making an ITX system just for the fun of it. I dont have a set build yet, although I've watched a few of the 350-600$ builds on tek and I like them but i feel like i might need something more suited for myself. Im not looking to overclock or anything wild, honestly just run my steam library and run league on Max settings 60+ fps. But a side thought was In my desktop i have a evga 660TI, would i be able to get that into a mini ITX system? So i can opt out of getting another lower gpu? Thanks!!!
Well, if $350-600 is your price range, you can do pretty well with that, and even keep your 660ti in the system you have.
http://pcpartpicker.com/p/2ETfh
I can spend that but I'd prefer to spend 300ish xD if I can cut a big corner and just swap gpu's when I have to is that a reasonable idea? I've never really taken apart my PC after putting it together lol would me removing and reinstalling my gpu over and over possible cause problems with it? I guess that's ultimately my question.
I don't think that would be very healthy for your GPU lol. I'm pretty sure the PCIe x16 slot is not meant to be an SD Card slot type deal-io. It depends how often you switch, though. The build I listed above might be able to replace your main rig as it's still pretty powerful.
Just slap in the 660ti, and if I eliminate kaveri upgradeablity, here's what you get:
http://pcpartpicker.com/p/2EUuT
What's your current setup anyway? I sold my old mid tower, went to mini-itx, and never looked back. Depending on what you have, you may be able to downsize and have a nice little rig for both uses.
If you don't mind turning down a couple settings, an APU can get you pretty far as well:
http://pcpartpicker.com/p/2EUty
Yeah lol i kind of figured it just sucks cause its so damn convenient x3 but right not i have a full size and certainly dont want to go to ITX for my main, i like the expansion possiblities and also am madly in love with the newly released corsair 760T, so thatll be in my hands asap xD but:
Thermaltake Revo Snow (Soon to be Corsair 760T ^^ )
Asus z77 Sabertooth Mobo
EVGA 660TI Gpu
Seasonic 650w 80 Plus Bronze PSU
WD 1TB Caviar Black
Samsung 250GB SSD
Hyper212 CPU Cooler
12GB Muskin Ram
Intel i5 2500K Sandy Bridge
Dual Asus 1080p LED Monitors 24 Inch
NZXT Fan Controller
Like 10+ Fans... xD But Whisper Quiet!
And im really not a fan of APU's, I've had one once before and it just felt slower overall. I'd like to stick to the gpu route
That's quite a nice rig. Since you don't want to downsize it, you can't do much with a $300 build. I'm sure LoL would run fine on an a10-6800k with fast ram (ts has a vid on the 6800k).
I just think that moving your gpu constantly back and forth between systems would be a hassle and a risk.
I understand and thank you for the input! Seems I'll have to pursue other means ^^
My opinion is, that you could scavenge the CPU, GPU, RAM, HDD, SSD and the psu from your old system, and put them into this NODE 304 case with a nice Z77 i-deluxe asus mobo and a corsair H60 AIO water cooler.
Your CPU is still a very good performing chip, and the GTX 660ti is nearly as powerful as a GTX 760, wich can max out almost any game on the market. And with that i-deluxe mobo and it's great ATX grade power delivery, you could get a nice OC for your CPU
Total would be 250$ http://pcpartpicker.com/p/2F8lO
I hope i helped :)
That's what I was suggesting, but that's not an option if he says:
Yeah i plan on keeping my full tower system just for expansion in the future and the ITX is just something cool i can bring with me to lan/school etc since i hate laptops and enjoy my peripherals lol Been toying with a spare PC i have that died awhile ago but it still boots, it has a crap gpu that I've been removing and reinstalling pretty much all day so I'm going to see what happens xD
