I bought a new computer recently and I'm trying to import all of my audio CDs onto iTunes. For some reason iTunes doesn't recognize the CD unless I open Windows Media Player. Only then does iTunes attempt to import the CD. Anyone else having this problem?
Try going into iTunes Edit > Preferences > When you insert a CD and change those settings to what you want. You may also have to go into Windows Settings > System > Default Apps and change your music player to iTunes.
windows 10?
if you're ripping CDs.
use Exact Audio Copy, and follow the propper ripping guide with gap detection and read offset.
