Memory overclocks have limited gains for gaming and can limit your core oc. I still oc mine, but only after reaching top stable core speed. If you didn't BSOD you didn't try! Just my opinion of course.
It's not like your loosing anything its free FPS. Also you should really benchmark more than one game do at least 2 more then try a benchmark like Heaven
as a whole it might seem trivial, and in many cases it might be, but when something isn't performing quite up to where you'd like a few extra frames can make a noticeable difference, and the big thing can be the much less crippling fps drops, as in that bench the minimum fps went from 1 to 10, both are bad, but one is significantly less bad
Like I said try a few games and 1 or 2 benchmarks. Overclocked performance may increase more in certain games. A good game to benchmark with if you have it is BF4 as although it has network issues the actual performance is very solid. Also I checked your profile to get an idea of what specs you have and more info would help. Oh and remove that link from your profile it's technically advertising.
