I have a USB DAC that had been giving me lots of issues, stuttering and stopping, and was told to try another USB port. It was in a USB 2 port and I moved it to a USB 3 port, this solved the issue.
To day after finishing up GTA V I exited the game to be met with a memory management bluescreen, restarted as normal and all is well except now the DAC is not making any sound.
I checked all the relevant things. Event manager told me there was a issue with the USB DriverFrameworks-UserMode and nothing will get the DAC back working.
The ports are fine, I have plugged thing in and out to test them. Windows knows the DAV is there and when it tries to play sound all appears well volume level move and such and the DACs light changes colours as it normally does but No Sound Comes Out.
Everything appear completely functional except that it is not.
I have rolled back drivers. Uninstalled and reinstalled, checked for hardware changes. All the usual suspects and nothing. Windows says all drivers are up to date and everything is functional, still no sound.
I can make it work back in the USB 2 ports but that brings back the stuttering and that in turn will stop videos and games to resync the audio which if I am on line mean stopping my character in place till resync and in a race for example will put me back positions, it picks up right where it left off but just freezes for a moment and them continues as if nothing had happened. I need the DAC back in the USB 3 port to fix this but it will not make sound on the USB 3 port even though windows says it is , every application says it is and all appears functional.
EDIT: It is a Driverles DAC so it is windows drivers and all is fine there according to windows so I have virtually no control over reinstalling better drivers. or trouble shooting them.
EDIT 2: the specific Event Viewer error is Event ID 219 https://social.technet.microsoft.com/wiki/contents/articles/3164.event-id-219-windows-kernel-pnp.aspx
EDIT 3: If it helps the specific driver that is the problem is USB\VID_0BB4&PID_0C93\FA34SW912017 no idea what to do with this information, if there is a specific way to get to it and fix it please let me know. FailureName \Driver\WudfRd
Please help.
EDIT 4: FUCK WINDOWS! Windows updates fixed it. While we are at it FUCK AMD, I want a Ryzen CPU and I want to run linux and put windows in a box so it cannot do exactly this shit, But NNNOOOOO screw your GPU passthrough and vitrualisation. I FUCKING WAITED FOR YOU! This is some bullshit.
EDIT 5: So started up my PC today after everything being fine last night once again and it is dead again. All the same problems. No idea how to fix it as it fixed itself last time through the magic of windows. So now I am completely stuck. PLEASE HELP!!!
