Issues with my 4670k or at least im assuming it is
I built a Computer.
alot of the time my Computer has a Hiccup. where if im multi-tasking with 6 or 7 windows 2 of the windows say not responding. my computer freezes for a couple of seconds. and then it goes back to normal. maybe cause i put to little of thermal paste on the CPU?
anyway to fix this?
heres my setup.
RM650w PSU
R9-270x x2 in Crossfire
4670k at Stock
Gryphon z87
Noctua L9i CPU Cooler.
16gb Corsair Veangeance LP 1600mhz
Your processor and RAM should handle that kind of multi-tasking quite smoothly. It depends if each of those several windows is particularly demanding. Can you open task manager and tell me what the component usage is?
Ram Usage: 14%
CPU usage 47%
this is also with a game open btw
Well that usage seems normal. Can you tell me what specific OS you are running? What -bit? Just a gut feeling.
Windows 8 - 64 Bit
All seems normal to me. I don't think it is a hardware problem, probably something in your OS environment. It's a small hiccup, I am sure you can live with. It's not a big deal. It will probably cease from happening after you do some monthly PC maintenance, with OS reinstall et cetera.
I guess. its more noticeable when i'm gaming thats' about it. thanks anyways though.
