As some of you may have seen in past , I have many montiors in my setup spanning into different rooms. I, just fixed up part of my basement and now have a workshop down there that i wish to extend my computer into.
I have 2 Amazon 100 ft amazon basics Directional fiber cables running down for 2 1080p monitors (Monitors 10 and 11 respectively) . They will recognize for a bit then spontaneously one or the other will eventually stop being recognized or start intermitently flickering.
The first thing i thought is perhaps my cables are the issue , but i ran these cables for about 3 days with the monitors connected with no issues. Now the issues have returned. The 9 monitors i usaually have connected run without any problems but the moment i connect either of these I start having issues.
I am considering Hdmi over ethernet but before i do that i feel i should probably rule out that it isnt the computer itself. I have 2 more of the same cables mentioned above going to cameras for the workshop room and they are running with no issues.
Just posting this here for any thoughts / comments on this.
If possible swap the 2 cables going to monitors 10 and 11 with the ones that goto the cameras and test again.
If the issues carry over to the cameras it’s the cables … if the issues remains it’s either the monitors or pc… if the issue remains try swapping out the monitors with 2 of the other monitors you have. if the issues follow the og monitors then I’d put the issue on the monitors if not then the pc.
So i removed the 4 monitors and added back the 2 basement monitors in place of 2 upstairs and everything has been working for several days no issues. I am taking that to mean that the cables are not the issue ?
Now i have reconnnected the 2 upstairs displays in place of the 2 basement displlays to see when (if) the issue starts happening again. Guess will find out.
[quote=“KittyNour, post:7, topic:219015”]
So i removed the 4 monitors and added back the 2 basement monitors in place of 2 upstairs and everything has been working for several days no issues. I am taking that to mean that the cables are the the issue ?
[/quote
Sounds like the cables were not connected fully. I’d say give it a week or so and see if any issues come back. If nothing comes back … it was just a loose connection.
