Hi,
I am trying to upgrade the network connection between my NAS and my main PC to 10Gb however I am having issues getting freenas to boot with the NIC installed.
When booting freenas first has issues trying to start the DHCP client and then crashes with the error code “Fatal trap 12 fault while in kernel mode”.
I’m pretty certain these are the cards that I’m running in my FreeNAS box. Though I’m not using the fibre transceivers. Are you running FreeNAS 9 or 11?
Perfect. I will have to spin up a FreeNAS box to test this. If I can get my cards stable on FreeNAS 11, would it be possible for you to use SFP+ cables instead of the transceivers, or are you tied to them?
I would greatly appreciate that.
I don’t own any of those cables but I am willing to purchase some in a effort to get this working.
Does what SFP+ transceivers are being used make any difference? I thought the OS just sees the network card and the network card deals with the transceivers.
Thanks
I would expect it just sees the network card and then that’s that. I just want to keep the transceivers on the table as a possible failure point. I’ll test my cards in FreeNAS since that doesn’t cost any money.
The VPI is a Virtual Protocol Interconnect Driver. Designed for Both Infiniband and Ethernet.
The VPI drivers… seem to have issues in FreeBSD. if it installs a control software to manipulate the device it may be possible to put it into EN mode. If not, you need different cards for FreeBSD.
Thanks for all of your replies.
I am currently looking for the control software but I am not having much luck. If i cant find it in a couple of days I will try and buy a different cheep 10Gb NIC.
