Is zwiehander on itunes?
So i want buy both albums, but i can't find zwiehander on i tunes. if zwihander isnt on itunes thats ok i will find a way, but i want to make sure that im not just overlooking something.
It's sold on band camp
Yes right here https://zweihander.bandcamp.com/
ok so can i download it to my computer?
Yes....
I have never used bandcamp before, i didnt know. thanks though.
I use band camp where possible. Their downloads are DRM free and available in any format under the sun, well that's a lie but you can get quite a few in any quality you could want.
And if you are away you can stream from band camp as well.
