It costs 72,24€ (97,30$).
Is it good? Worth buying it?
well there is better cases for the money
In got mine here in France for about 55 euros. And for that price and with all it comes with, it is a fantastice case! I would recommend it if you could find it cheaper.
I live in Slovenia and prices here are higher than in other coutries :/. This case is one of the cheapest (Fractal Design Define R4 is 114€ (153,55$)for instance)
I absolutely adore mine. but i also got mine for about $25 dollars cheaper. and its not without issue. there are like 100billion fans and places for fans (not the acutal amount its more like 8 - 10) and ive filled all of them to the max which is fantastic for cooling and since i dont use shit fans noise isnt an issue but the wad of plugs i have from all those fans is really tough to stash away. also my PSU doesent fit perfectly but im not sure thats the cases fault or the PSU (im betting the case) but all in all it cools well and looks freaking awesome. there may be better cases out there but if you like thaqt style of case youll be pretty hard pressed to find another like that thats good at that price. although ive heard some good things about the NZXT Vulcan (http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065)
dude, I live in Slovenia and prices aren't that high. Sure the fractal cases are more expensive if you convert the money. Keep in mind dollars don't get converted into euros. If a case is 120$ in the US, it's gonna be 120 euros in all of Europe. Jebi ga, tko pač je.
i bought this case recently and am very happy with it. for the money it's a great case
Dude here in the Netherlands the zalman z11 plus is the same price as the zalman z11 NEO. And the neo is way sleeker and has a nicer finish in my opinion. So if it is available in your country i would defiantly take a look at it. But the plus is fine either way!
