both eaton and apc come with software for windows that will shutdown the PC in time, even if your not around. And both (the eaton way better) have linux support as well.
Cyber power has that feature as well
Even works with Freenas
Depends on what your graphics card pulls during load. Your displays will pull a max of somewhere around 30 watts, and a 1000VA UPS has about a 700 watt capacity so you don't have to factor displays into the equation nearly as much as you do full system load. If you have something like a Core i7 and a high end graphics card you're looking at somewhere around 400 watts, which the UPS will take but in the event of a power outage wont last very long.
Hi,
i'd like to hijack this post.
Same question, but different PSU.
IBM 53961KX 1000Va
I actually searching for the 1500VA version but no luck so far.
that is the 53962KX
I couldn't figure out if it is actual sineWave and if it beeing old should be a problem.
This ebay post states in german that its from military storage.
Thanks!
