Is this too hot?
ok, my video cards are hitting about 66 degrees Celsius.... (151 degrees Fahrenheit)Â is this too hot?
they are the ati HD4890's
this was playing garrysmod with all the settings set to max.
No its fine only time when you should be turning up the fan is when it starts to hit mid 70's low 80's.
GRAY FOX
??? wtf does that mean???
@gonemad thanks for posting a helpfull reply...
 oh and btw, i know its not a true review, but the 4890's are amazing had the settings maxed out on gmod and i was getting like 200-300 fps in game exploding nukes and stuff... and like 350-375 just standing there. can play crysis with no apperent lag (not shure exactly how much, but benchmarks say 55 and xfire was saying around the low 50's)
Donw worry, those video card can go up to 90 degrees and they wont crash, my 4870 X2 went to 94 and nothing happened, spinned the fan up faster adn temp went down to 60s.
Hurt me MOOAAR SNAKE!
If it's idle temps, yes its too hot.. turn the fan up
It was when playing Garrys Mod.
First posts last sentence FTW!
Ok..... were good to go then
