I just purchased an RX 5700 XT Sapphire, it’s making a very annoying ‘clicking’ sound when ever a game is playing is this normal?
I have uploaded a YouTube video of it - Sapphire RX 5700 XT ‘Clicking’ Sound - Unfortunately my mic on my phone doesn’t quite capture how loud the sound actually is, I don’t mind the blower, but the clicking is another matter.
It doesn’t seem to be tied to the fan as I can hear the blower spin up but it makes a completely different sound your typical blower sound. It was hard to capture but when I zoom in and out in the (oxygen not included) you hear an audible change in the in the clicking noises tone ,
Unfortunately my house mate is making a bit of noise at the moment, I will try and capture the sound difference. but it seems mind blowing at me at least that a graphics card in this day and age would create such noise.
I was able to capture the following clicking sound whilst scrolling in the view in Oxygen Not Included, Sapphire RX 5700 XT ‘Clicking’ Sound Changes With Scrolling unfortunately the video once again fails to capture how loud the clicking actually is.
But as an aside in my annoyance I suspended the process for Oxygen Not Included, and the sound stopped right away, and yes resumes when I resume the process. so in my mind this eliminates the blower as the culprit as it’s still blowing as before to cool the GPU.
Really high framerates make coil whine more apparent. If you have a game or a loading screen that takes your framerate to 3000fps give it a go and see if the noise changes during those FPS spikes.
Anyway that noise sounds like a fan constantly hitting something. Can you try to stop the fan with your finger for a sec to make sure it’s not the GPU fan?
Well yeah coil whine can be pretty anoying.
But not really much you could do about it unfortunately.
The only thing you could try is contact Sapphire about it,
and make a complain about it of course with the video.
Maybe they let you send the card in for an rma.
And when lucky they might send you a new card.
However coil whine basically is always present kinda.
It´s just that with some cards its more audible then others.
I had this experience with my Sapphire 480. It was their drop-in fans that caused it. I had an absolutely terrible experience getting a replacement fan. Not sure if your issue is the same as mine was.
Thank you for all your comments, sorry for my delayed response I have found myself very busy recently, but your all your comments are very enlightening indeed.
I can say with quite high certainty that this isn’t a fan related problem, as I can influence the clicking noise and completely stop it by stopping/pausing the process that performing intensive GPU load, which would suggest that the coil whine theory is probably the most likely.
I have also now notice the system in general has become extremely unstable, with a range of different kernel panics, which is frustrating to say the least, I haven’t been able to open the memory dumps yet to confirm whether or not that’s its the Radeon drivers, but my gut feeling at this stage is it is, has anyone else experienced there rigs becoming unstable?
Do you have another GPU to swap out for some testing to see if the noise goes away but more importantly, does the system become stable ?
Stability could be caused by many different factors, memory, power, mobo, etc…
If the GPU is at fault, it could be causing the stability issues and swapping it out to see if this goes away would indicate a failing GPU which I would then submit an RMA Request.
I have had it blue screen in both full screen an in non full screen applications. But I can almost guarantee it if I use FireFox on Facebook for long enough funnily enough but I’ve had a BSOD playing Oxygen not Included as well.
I have attached a picture of what I saw, in one example, here it clearly says atikmdag.sys, so I am going to gander that it was indeed the Radeon drivers,
Radeon Software Version - 19.8.1
Radeon Software Edition - Adrenalin 2019
Graphics Chipset - AMD Radeon RX 5700 XT
Memory Size - 8176 MB
Memory Type - GDDR6
Core Clock - 1755 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 32 GB
CPU Type - Intel® Core™ i7-4790K CPU @ 4.00GHz
