http://www.ebay.com/itm/600-Watt-600W-ATX-Power-Supply-SATA-Dual-80mm-fans-Silent-for-Intel-AMD-PC-Unit-/271198844722?pt=PCA_UPS&hash=item3f24b5f732
Found this on ebay. It's pretty cheap so i'm a bit skeptical of getting it. What would you guys rate it? Would it work with my build?
My build:
Motherboard: MSI Socket-(yada yada yada) 1 PCI-E (1x16), 2 PCI-E x1 and 1 PCI
GPU: Radeon R9 270x
CPU: AMD Athlon X4 750k
PSU: Hopefully the one I found on ebay
HDD: 1 TB 7200 RPM, SATA 6 Gb/s
RAM: Kingston 8GB(2x4GB) DDR3
Case: Fractal Design Define R4
